Discuss Back box earthing in the UK Electrical Forum area at ElectriciansForums.net
My bad...as the youngsters say!
but, for accuracy...ye actually can shove yer granny aff a bus...however I would not condone this...apparently this is rather non-PC...IIRC, it was envisioned that you could indeed shove your Granny off the bus, but not your mammie's mammie, but rather yer daddie's mammie...
I do feel that this distinction is unlikely to receive judicial approval in these enlightened times ...
….Time for you to walk the bleedin' plank...…….:)
Reply to Back box earthing in the UK Electrical Forum area at ElectriciansForums.net
I have just checked a double outlet and it trips at 18ma. It was supposed to be faulty. Washing machine had a bad heater which got replaced but...
Hello everyone, Following on from my previous post where I received advice on taking a spur off a 40a feed (thank you). I performed the work...
Greetings, I am homeowner and looking to confirm if I will need earth boding to water pipes. There is already earth boding near Gas meter and the...
I have a known working TV and went to set it up in another building for an old chap. He has about 3 TV's already. I connected the TV to 2 seperate...
Hi, This post is about my concerns with medical IT socket outlets and want to alert you all if you are fitting them in a hospital. The current...
