Discuss Back Box In Hollow Wall Installation in the UK Electrical Forum area at ElectriciansForums.net
Plasterboard adhesive - doesn't shrink when it dries so it's perfect for this application. Whack it in there, sink your metal box into it so it's flush and let it dry. Make sure to grommet your entry hole before putting the box in or make sure the entry hole is completely free of adhesive before you walk away from it.
This stuff would be far better and will not allow the box to pull out with the plug: Rawlplug R-KEM II Styrene-Free Polyester Resin 300ml - https://www.NoLinkingToThis/p/rawlplug-r-kem-ii-styrene-free-polyester-resin-300ml/32863?
Just done a Rewire exactly like this, literally finished it yesterday
knock the horizontal lips off the adjoining blocks flat to the back then
just cut 2x 4 inch piece of 1x1 wood batten(stuff that’s used in packaging for integrated ovens is best😀) and liberally no nails them to the flat back of the blocks(one above and below the horizontal lip of the block is best but it’s gonna depend on whereabouts you chase in) don’t try to glue them to the rough lip only the smooth flat bit!!)
leave it until the next morning then just fix your metal standard back boxes with 1in x8 screws
sorted and solid as a rock, if you use 35mm boxes it should work out near as damn it to flush of the wall
when I bond the chases afterwards I always make sure I squeeze loads in around the socket boxes to give it that bit of extra support but it’s fine honest!!
if you think your gonna cut a plasterboard box Into it your dreaming 🤣
Reply to Back Box In Hollow Wall Installation in the UK Electrical Forum area at ElectriciansForums.net
I'm installing smart modules in my light switches which means I need to replace the existing 25mm back boxes with 47mm ones. Downstairs all walls...
Need to replace an old Vent-Axia extractor fan as the pull chord no longer works. I bought this -...
Hi I'm doing a rewire of an old victorian terraced house built in the 1890s the plaster and bricks are extremely fragile even with a hammer and...
5K
I am interested in having a home generator that would provide power to my home when the power is out during hurricane season, etc. I have 2...
