N
nicebutdim
Thanks NbutD. I am dealing with a 60mm cut out currently but could deal with that by maing blanking plates. Will take a look at the ansell product.
Just realised it was the lens size you'd referred to and I'd been under the impression it was bezel size.
I've fitted a few of the units linked below now. 70mm cutout (easy for you to enlarge existing holes), smallish lens (although not quite as small as you've been tasked with finding), fire rated, IP65, 5 year warranty, choice of bezel finish.
Colour temp is also selectable from under bezel. I don't imagine many people change colour temp once lights are fitted, but like the idea of not needing to pull it out of the ceiling if one should happen to be set incorrectly.
Edit: Almost forgot the best bit - prewired with quickwire T-connector, so 60 seconds to 2nd fix as long as wired in T&E.
Quickwire-Ricoman Fire Rated Downlight
Quickwire now provide a market leading fire rated downlight that comes factory fitted with a Quickwire plug & socket.
