J
jwc
Hi all. Fitting a bathroom extractor at the weekend. The fan had a switched live and neutral. Wondering if a isolation switch and fused spur are a must? Was planning on taking a feed from the bathroom light so the need for a spur might scupper those plans a tad.
Thanks.
What does the isolator manual say?
I mean Fan manual
The bloke who i'm fitting the fan for acquired the fan and no longer has the box/instructions.
Google the make/type of the fan and download the manual..
Your responsibility is to install using BS7671 and the manufacturers instructions - surely you know this?
Thanks.
So the fan has no permanent live? And why can't you connect to the lighting circuit just because the fan needs fusing down? Pretty basic stuff. I've done this hundreds of times!
Just to add to your joy, depending on how you are installing this and where you are fitting the fan, this work may be notifiable.
Thanks.
Are you DIM
You need to read the manufacturers instructions. You must install to BS7671 and the manufacturers instructions.
