Discuss Bathroom junction box lighting in the The Welcome Forum area at ElectriciansForums.net
Shaq
Hi, im trying to fit spot lights in a bathroom.. the main is currently out of a wall with a small amount of cable on it, can I use block connector with black tape and sink it so I can extend the wire to run further from the bath? If not can I use an ip65 rated jb sitting about 170mm away from the bath and 2.25m high from the floor?
NO! you cannot make a connection like that and hide it in the wall.
I guess you have access to the loft above?
Go there and find the cable. Make the joint up there.
PS when you say
What do you mean? is this a permanent live, or is it the switched live and neutral from a previous light fitting?
This is the main permenant live and its only about 4inches worth of wire to play with. Was told I can use a waterproof junction box?
PS when you say
any RCD PROTCECTION on that circuit ?
Only if you are registered with one of the C,P,Schemes
Reply to Bathroom junction box lighting in the The Welcome Forum area at ElectriciansForums.net
I have 16 ceiling spots to be replaced in a room being repurposed as a bathroom. Some will be over a shower, basin and bath hence need to be IP65...
Hi, i live in a new build house where they builders have left a junction box on the outside of my house. In the junction box there is a 6mm twin...
Hi, Hopefully I haven't made an error but I was speaking with another electrician and he said standard junction boxes with screw terminals can no...
Hi I've been planning to fit an outdoor junction box at the front of my house to hide a large brickwork hole and properly house the wiring...
