Discuss Bathroom light fiiting regulations in the UK Electrical Forum area at ElectriciansForums.net
Just wanted to pick peoples brains I'm currently having some work done at my house and I've noticed that I currently in my bathroom I have a bayonet fitting that is connected via a very long cable light you would get in a front room, the light itself will just be above the edge of the bath.
I've had an electrician out and he has advised that it should be fine but I wasn't sure if this should be changed to an ipx4 type as this is what my mum and dad have in their bathroom and they then have a glass bowl that screws over the light.
I've attached a picture of the light fitting I currently have in my bathroom.
Any advice and guidance would be greatly appreciated.
Cheers
Check below link, good info there.
Zone 1 and 2 needs at least ipx4 zone 3 does not need it but I would still fit ipx4 fittings as you get lots of steam and condensation in bathroom.
What are Bathroom Zones? | IP Ratings Explained | Downlights.co.uk - https://www.downlights.co.uk/faq-bathroom-zones.html
zone 3 has not existed for several years. zone 1 agree with IPX4. zone 2 can be a lesser IP rating , but IPX4 is good practice. either way, the OP's current fitting does not comply as it's a pendant. condensed water vapour runs down flex into light .... bang.
Yes it's "outside zones" now.
I don't have a regs in hand but if I recall correctly section701 requires that electrical equipment in zones 1 and 2 shall have a degree of protection of at least IPX4.
I would certainly change it, and would change it to one with a suitable IP rating and also make it an LED version. Very small outlay and will be much more efficient and most likely last longer (assuming you get a decent one).
must be getting soft. that's 3 agrees with DPG in a week. :eek::D:p;)
nope i am TEL I not III.that would be my grandson, due to be popped out in a month or so.
Ah upper and lower case I and L confusion :)
Congrats on the imminent arrival!!
got a grand daughter 3 yrs. now son has managed to get the right XY in there.
Reply to Bathroom light fiiting regulations in the UK Electrical Forum area at ElectriciansForums.net
Hi. I know this probably isn't the most fitting platform to post this question, but I was racking my brain where I could get an answer to my...
Hello, I currently have two switches in my bathroom. One controls the lights above the sink and the other controls a light above the toilet and...
This could possible have been a poll, but really just opening up for suggestions and feedback on where folks think an isolation switch for an...
Hi all, wonder if someone can help me. I've bought a bathroom extractor and I do have the wiring there already (previous extractor was there) but...
I'm not sure what's going on with my kitchen light. I've replaced an old 28W CFL fitting with a new 4 x LED GU10 fitting (a cheap one from...
