J
Jb1410
I’m currently upgrading my bathroom suite and was wanting to remove the old style pull chords style switches for the fan and light for a switch. They will be mounted well outside the zone 2 area in the bathroom so do I need to take any ip rating into account as well. Many thanks
No problem at all, although you'll still find the odd (in more ways than one) electrician who says otherwise.
The older regulation which stipulated "out of reach of a person using a bath or shower" is arguably a better reg than the current one referring to zones.
The circuit should be protected by a 30mA RCD, of course.
To avoid any confusion with future electricians, just put the switches on the outside of the bathroom. Back to back from where you might put them inside.
Thanks for the reply
It's a problem that just does not exist. Standard plate switches are more than resistant enough to moisture so as not to cause problems.
I've always installed wall switches in bath and shower rooms over my entire career, apart from the few where the bath or shower is next to the opening side of the door and only then have I fitted a pull cord or outside switches.
I have never received a single report of someone ever having received the slightest of tingles from one of my switches.
Although it's permissible outside of the zones I prefer to put wall switches outside the bath or shower room, just doesn't feel right as moisture and steam take no notice of BS7671 zones.
I must admit I don't like standard switches inside bathrooms. The amount of steam after some people have had a long shower is much like a sauna. And such a switch would not be allowed in a sauna.
Plus the danger of dripping wet people switching the light on.
Just doesn't sit right with me. What's the problem with a pull switch anyway?
This subject is actually the reason I found and joined this forum several years ago.
The one time I've fallen foul of this Part P/3rd party inspection nonsense was on a pair of barn conversions where all out war had been declared between the owner of the barns and the local building control.
The 3rd party inspector was the owner of a local electrical contracting company, who was absolutely insistent that my plate switches inside the bathroom was unacceptable. We had the regs on the table in front of us, but he still wouldn't give way. He just couldn't see what the wording actually said, rather than what he wanted it to say.
Doubting my own sanity, I joined this forum, intending to post the question, but a search revealed a recent thread discussing the exact same thing, and showed that I was correct.
Switches went in the bathroom, and presumably he submitted his EIC to building control. Never heard any more about it.
When it came to the second conversion, I just submitted my own EIC as normal.
There are now glass fronted touch screen switches which offer high ip ratings. These are dimmable for the spot lights I’ve put in and just feel like it gives a more modern look. But they are really expensive haha!! Thanks for the info
Why should he change his plans just because there are electricians out there that don't know their job?
You surprise me Brian, and what if there is no RCD protection (I still would not). The OP has not mentioned that, would you still fit a switch inside the bathroom.
Is a pull switch mounted on the ceiling where steam congregates any more resistant to moisture ingress than a plate switch? (rhetorical question) I suppose it's origins is in the fact you can't touch the switch itself, so is the IP rating of a switch relevant?
