Discuss Best cutters/strippers in the Electrical Tools and Products area at ElectriciansForums.net
As above, CK cable shears. My current one's I've used for around three years daily cutting through 10-35mm cable and they're still sharp.
you can use shears. just personal preference.
Using shears for stripping can score the conductors so to avoid this you could use shears for cutting and a knife for stripping.
It's all down to personal preference.
Any decent brand cable shears will cut 16/25mm copper
For 35mm and above I have some old ratcheting cutters (were my dads) like this
I also use it for small armoured as well
Reply to Best cutters/strippers in the Electrical Tools and Products area at ElectriciansForums.net
Has anyone come across automatic strippers to pull of the sheath of a cable already in a back box. The regular ones can do it to a degree but due...
I experienced an electrical shock while replacing an A/C Fan Coil's 120vac, single phase motor that was above the ceiling grid in an office, while...
4K
I’ve got a makita wall chaser. What is the best one. Mainly 20mm chases.
So, I actually brought a set of knock off install pliers like the ones in this video... and just like the guy in the video, I found the cheap...
