Discuss Big Problem in the Industrial Electricians' Talk area at ElectriciansForums.net
C
core404
Hi
First of all i would like to openly admit to you all that i am no electrician .
This is my problem :-
I was installing a new ring into the fusebox via a new 32a fuse round at my friends house as he as strangly only got 1 single socket in each room of his house and was a bit annoyed in having to use extension cables all over the house .
But when installing the 6mm twin and earth wire via the new 32a into the fuse i box the mains cable coming from the meter to the fusebox mysteriously came away (i was shocked , not literally quite thankfully)
Is there anyway of disconnecting the power supply before the fusebox so i can safely put the wire back into place .
Thanks and sorry
Joe .
Its no wind up !
yes i installed 6mm twin & earth to an isolator from there i ran 2.5mm to the double sockets.
"should be sir, hope you know what your doing. im not liable for death"
thats why i'm asking for a safe way to disconnect the mains before the power hits the meter/fusebox so i don't get electricuted mate.
how can i do this ?
Joe
tbh i cant really afford it and as it was me who was doing it for my mate and now he as no power what so ever it should be me who rectifies this problem.
could you just tell me how i can disconnect the power supply please ?
i really think you should ask your bank for a overdraft and call in a electrician.
you obviously havnt got a clue what your doing and could hurt yourself or others in the process.
get a professional in to sort it for god sake
It's like everything - easy when you know how. See, the thing is - I will not advise you on what you need to do as I think it is too dangerous for a 'novice'. By the sounds of it you need to safely isolate the consumer unit and re-instate the tails in order to restore power. I couldn't sleep if I knew I had tried to give you the 'on-line' tutorial of how to do this and you ended up seriously injured - or worse. I know pride is a big thing but please, just pay a sparky a few quid to make it safe. It won't cost the earth and will take him 5 mins.
Core404 where are you located mate?
Post some pictures if possible so we know what you have dissconnected exactly.
Cirrus is right it would be wrong to give a step by step guide to you as a novice.
Dont worry about it ,just put the wire back where it came from ,there is no need to turn it off as long as you are carefull, pull all the fuses out first ,so theres no load ,and just put it back in ,simple
good luck
seriously you get it wrong its a potential trip to the hospital or /and a call to the electric board . they frown when experienced guys do it right and prosecute when amatuers do it wrong!!!
also they is the whole issue of part p ........but i suspect your not worrying about that;)
Certainly a BIG PROBLEM
DIY MUPPETS SHOULD LEAVE WELL ALONE
Are you going to do a Building Notice or just break the law?
Actually we need a High Profile DIY Death to raise public awareness, as John Prescott didn't fulfill his side of the bargain.
Reply to Big Problem in the Industrial Electricians' Talk area at ElectriciansForums.net
hello all...whats the typical cost for a new consumer unit fitted and the old wired fuse box removed im in a semi detached house in...
Hi, i live in a new build house where they builders have left a junction box on the outside of my house. In the junction box there is a 6mm twin...
  • Locked
My house was built in the 1930s, The fuse in my service cut out is 60Amp and the wire coming from the street has a 16mm2 copper core(easy to see...
Hi there, I was wondering if anyone could advise me on the WT Henley Series 8 house service cutout. I have one of these installed at my house and...
