Discuss Bonding gas and water in the UK Electrical Forum area at ElectriciansForums.net
Hi guys
Does the earth Bonding HAVE to be done at the meter or can it be put on the gas inlet to the boiler in a utility room? Plans have changed and cables already run ?
Also am I right in thinking that if water inlet is in blue pvc pipe Bonding isn't required even tho it is copper on outgoing side of stop cock?
gas bond should be as close as practicable to within 600mm from where it enters the building and before any joints. if pipe is direct from meter to boiler, then no problem. as for the water, test the copper in case it's extraneous. >22k resistance to MET no bonding required.
I'd say it's definately over 600mm
Looks like I'm gonna have to clip it around the outside of the house
regs say a close as practicable. to avoid pikey bait on the outside, near boiler is as close as pracicable.
Reply to Bonding gas and water in the UK Electrical Forum area at ElectriciansForums.net
Doing an EICR on a commercial install, there’s a copper pipe comes down a pipe chase with the stop cock fitted onto it, it’s then pvc pipes that...
I know once you see plastic entering then you don’t need to bond as it says on site guide.(enters the house plastic then it’s metal) Would I be...
Not sure on this one. Mains water is coming up from the ground in lead pipe in bathroom. 2 inches of copper pipe before the stop tap. All...
What are the regulations requirements on Earth bonding ? I am currently planning a 1st fix re wire I have the following setup Gas Meter...
Hi forum members, I hope someone can assist with my enquiry. I have been advised that to comply with BS7671 Reg 132.16 my solar and battery...
