Looking for some advice on bonding. I've got a domestic property with a copper oil pipe coated in plastic which runs underground.....does this need bonding? Does the plastic coating essentially insulate it from being in contact with earth? or could it still be an extraneous conductive part?
I've got no way of testing it independently without dismantling the boiler as it enters the boiler into the metal manifold shared with the metal water pipe.
And if it does need bonding, anyone got any advice on how to get a good clamp on such a tiny diameter pipe
I failed my first NicEic assessment because I hadn’t bonded a plastic coated oil pipe that came from a plastic tank at the point it entered the cellar having passed through a 3ft stone wall. Partly because I couldn’t guarantee the plastic coating hadn’t been damaged where I had pushed it through the wall and I’m sure because I hadn’t been Abel to explain exponential bonding fully . On the next job I did bond the oil pipe and the same assessor guy asked why did you bond it ? I said so you wouldn’t ask me about exponential bonding and he said fair enough and passed me🤷🏻‍♂️ I just used a javelin clip with a small bolt through the tail
Upvote 0
Dehn earth pipe clamp d 10-27mm
Upvote 0
