There won't be, will there?
I assumed you were referring to 411.3.1.1 and/or
412.2.3.2 which mentions future replacement by class I equipment.
Presumably not affecting the bonding or earthing which will already be there (if required) complying with the above and 701.415.2 (first paragraph).
Okay Geoff, now read post 77 again.
Ah I see, apologies.
However, in your post 89 did you actually mean an 'unearthed exposed-c-p'?
I'm just making a point, if you see no bonding in place, then rectify the situation, whether you are installing class 2 equipment or not!!!
Indeed, my point exactly. My recommendation to the customer to have the lack of bonding rectified would not be dependent on whether or not the class 2 equipment was being installed; and installation of the class 2 equipment would not be dependent on the presence of the bonding. As the class 2 equipment is not reliant on the bonding for its protective measure, they are unrelated issues.
