Discuss Bootlace crimps / cutters in the Electrical Tools and Products area at ElectriciansForums.net
The blade under the jaws at the top of the handle cuts the wires..
I started using them a few years ago for doing all my control panels, saves me lots of time
this is probably the best if you only do one conductor size, there are no changeover jaws so you buy a tool for each conductor size you want.
there is a vid on the site that shows it in operation. please note this is £1000 per size of cable.
I do A LOT of panel work and have not been able to justify the cost.
The one I use day in and out is the stripax one listed above.
https://www.phoenixcontact.com/onli...tegory_pages/Mobile_hand-held_tool_P-25-02-11
mine are almost same as them, but were £14.99 with a kit of 1200 assorted ferrules included. £170+ jeez. that's a week's beer money.
what cost????? and then you need to buy taped ferrules to load it.
these are at a cost of £1000 per size of cable.
they do if I remember correctly
0.5mm
0.75mm
1.0mm
1.5mm
2.5mm
so if you want a full set then it will cost you about 5K
if you ask nicely they might throw in a couple of packs of ferrules for free.
Reply to Bootlace crimps / cutters in the Electrical Tools and Products area at ElectriciansForums.net
As I have retired now (really!) I have decided to sell my electrical tools etc. They include hand tools, hilmor galv. conduit bender 20/32 with...
Hi Guys Only recently (used many moons ago when worked as a commercial spark!) got into using bootlace crimps again, wish I'd done this sooner...
Hi, I have always used banjos when earthing the armour on an SWA but have now switched to earthing nuts. I am making off a 10mm fly lead to the...
Hi all, Hope this thread is still going. I had to cut my stereo antenna cable, so need to reconnect with another cable. I am unsure as the best...
I have a redring water heater with a blown thermal fuse.Trying to keep all original wiring,sleeving etc.Finding it hard to source ferrules to...
