Discuss Bosch boiler problem in the Central Heating Systems area at ElectriciansForums.net
hasel5
Hi there got a worcester greenstrar RF18i that has the following problem
When both channels on programer are off the boiler runs on for a predetermined time for the pump overrun etc as it should. It then seems to fire intermittently after this causing the rads to still get hot with both the channels off.
Have checked all the connections etc and all wired correctly checked the voltages at the boiler all ok not a crossed permanent live with switched live.
Has anyone any ideas ?
Regards Hasel5
I am a bit stumped as not a new install and have inherited from the plumber lol
check and see if the frost stat is turned up too high.
Reply to Bosch boiler problem in the Central Heating Systems area at ElectriciansForums.net
Hi, We’re having problems with our Bosch serie 6 washer/dryer. It’s about 6 years old. The model number is WVG30461GB/03. It has begun to stop...
Hi there, the heating system I am working on has 6 zones and valves for each zone which was working fine with one boiler and one pump. some rads...
I have a Firebird oil boiler that is controlled by a Honeywell timer (no thermostat) that has channels for hot water and central heating...
Hello there, I’m in the process of mapping out a relatively standard S-plan system for my parents central heating and hot water system. Not sure...
