Discuss Bulb replacement in the UK Electrical Forum area at ElectriciansForums.net
C
cascade
Might seem obvious to you but are all secuirty light bulbs ( ie cheap ones from band q etc ) the same size?
Been told to get R7s ( whatever that means) and they should fit
R7s is the standard 118mm 500watt ( sometimes 300watt) halogen tube size and fitting. the 150watt are smaller, forget the code for them.
I think the R7's are only 80 - 100 watts for the B&Q security lights, i believe you can get an LED version, though it will cost considerably more than a standard bulb.
Just take the old bulb out to find what wattage it is, easiest thing to do.
Reply to Bulb replacement in the UK Electrical Forum area at ElectriciansForums.net
Hi all. Slightly out of the ordinary, but I'm looking to replacing between 60 to 100 standard size E27 bulbs with LED equivalent. The catch is...
Hi we are replacing light fittings in our home. Im confident with the fitting aspect, but have run into doubt in making the right choice of...
Hi everyone :) my first post here. Quick background I'm a newly qualified installer of somewhat advanced years whose just starting out in the...
My kitchen has track lighting. It consists of three halogen light bulbs. I've had the fixture for more than 25 years with no issues. Last night...
Hi all, Im new to the forum and wanted to check something and maybe get some advice confirmation. Ive got halogen wall lights which use a...
