R
roboze
Hi All,
Quick question, anyone know if anyone makes a bulkhead with PIR that works like some of the newer halogen floods.
ie, you leave the switch on and it works of the pir, then you flick the switch a couple of time and it overides and stays on etc.
been asked to change a light for one with a PIR and only have a switched live and neutral present, and re-wiring would be a pain the rectum!!!
cheers :)
(think that makes sense!!)
There are plenty out there, make sure that the box has on it 'manual override' ask in the wholesalers.
I have been using fittings from KSR recently and they are not bad these guys used to work at or own JCC, they supply most wholesalers, it also helps that I can turn up at their industrial unit in portsmouth to grab extra catalogues.
