Discuss Buzzing from kitchen lights in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Richx
Please can you help?
I have 2 lighting circuits installed in the ceiling in the kitchen
- newly installed.
Both on separate circuits with independent switches
It is 8 recessed LED fittings For each
One set is silent when on
The other set has a pronounced buzzing sound when turned on. This I guess comes from a “transformer”?
How to solve the noise please? (Not by me but what do I ask an electrician about?)
Are you saying that the lighting is supplied from 1 Fuse /OCPD/Circuit Breaker?
Hello and Welcome.
Sorry to hear about the buzzing. Can you say a bit more about it? Do the lights work normally otherwise? Have they always buzzed? Are they on a dimmer switch?
Lights work normally.
Always buzzed since installation
They are On a dimmer switch.
can you trace where the sound comes from. it's more likely to be dimmer than lights. maybe borrow a stethoscope from you friendly neighbourhood sawbones.
in that case. I'd get the sparks who fitted them back to replace it. it will be the driver in that particular fitting.
Reply to Buzzing from kitchen lights in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Hi all I'm after some advice on 2 way CU in a garden office which is 'buzzing' when I turn on or increase the tempreture of the wall mounted...
Hello all- I hope this is the right place to ask this question. A few weeks ago the LED lights in the kitchen started flickering intermittently...
My kitchen has track lighting. It consists of three halogen light bulbs. I've had the fixture for more than 25 years with no issues. Last night...
I am currently looking to add 12v led cob strip lights to my mother's kitchen but confused what I need. There are currently mains wires under the...
This is the second set which won't work to replace the current spots here in my kitchen. All they do is flash once quickly. I'm replacing...
