Discuss Cable Calcs in the Australia area at ElectriciansForums.net
bbq
i have just had 1st bbq this year
i like a nice juicy sausage
Mark can you rephrase that just to clarify how you like your SAUSAGE?;):D
Well depending on number of cores and installation method this exceeds the CCC of the cable.
It might just be me but I wouldn't entertain the idea of protecting a 2.5mm with a 32A MCB regardless of what the book says it can handle, it just doesn't sit right. 20A MCB max.
agree with that..2.5mm=20A, 4mm=32A.
I always wire garages in 6mm on a 32A ...extravagent or what?
talking of banjos (the forbidden word) has anybody else used these, i think they are fantabulous.
i dont get them from tlc but gives you an idea
Piranhna Earth Nuts - Pirahna
Must admit i always do 32A on 6mm.
Strange really considering 6mm is not really suitable for 40A MCB if the load is ever beefed up, so why dont we just use 4mm?
What do you call Banjos then yer look toms playing his frying pan again ! not to mention the battle of the (frying pans) :D
View attachment 262[/quote]
Yer saw these at my local suppliers think i will have a go on these ! Piranha :D
Or...
A stringed instrument comprising 4 strings designed to be played by holding in two hands one to alter note pitch and one to pluck the afformentioned strings in order to produce the desired note.
If you want to be P.C!!!!!
Or...
Isnt that a Ukulele like the one George Formby played?
" Leaning on the lampost on the bottom of the street "
"For a certain little lady to walk by"
" O me o my"
all together now!!!!!!!!!!!!:D
YouTube - Leaning on a Lampost - George Formby
:pThe origional
When you want genuine music - music that will come right home to you like a bad quarter, suffuse your system like strychnine whiskey, go right through you like Brandreth's pills, ramify your whole constitution like the measles, and break out on your hide like the pinfeather pimples on a picked goose - when you want all this, just smash your piano, and invoke the glory-beaming banjo! - Mark Twain
The PC
When you want genuine music - music that will come right home to you like a bad quarter, suffuse your system like strychnine whiskey, go right through you like Brandreth's pills, ramify your whole constitution like the measles, and break out on your hide like the pinfeather pimples on a picked goose - when you want all this, just smash your piano, and invoke the glory-beaming earth tag! - Mark Twain
Not got the same ring to it has it?:D:p
on the site im on alot of the people are from sheffield and they call the banjos monacles as in the single eye glass a bit strange but thats what they grew up calling em
Sounds good to me, however, im sure the slightly sight impaired may take a dim view.:rolleyes:
Anyway, how the hell did we get onto "earth tags" from cable calcs??:D
Reply to Cable Calcs in the Australia area at ElectriciansForums.net
Hi, if getting back to the CU is not an option, instead of spurring off a socket via a Sfs putting the rating down to 13a. Could you spur off the...
Client currently has a DB in his outhouse. It feeds a pool pump and an air source heat pump. It is currently being supplied using a 4mm T&E cable...
A friend of mine wired a 10mm 3 core armoured cable to his shed before I got involved and wired it himself already. He wants make it an air bnb...
Hi, go easy on me please, I've just returned to the trade, well I am about to, I received my Gold Card last Thursday. I've been gen'ing up for a...
