Discuss Cable calculator for Android? in the UK Electrical Forum area at ElectriciansForums.net
imago
Yes I know it's lazy, but can anyone recommend a cable calculator for Android phones? There are a few available by the looks of it, but a recommendation would be helpful.
I would also like to know if there are any good ones out there.
I have the free megger one, but it is very simplistic and limited. It is however ok for quick on site calcs.
Could be i use samsung devices. But the draka one lets you select a cable type and asks for cable length, istallation metod, volt drop, design current, grouping, 3036 fuses present, fuse rating and nominal voltage so fairly solid information for it to make a calculation on
Hi there,
I've just joined and saw your question appear as a related item to my first post! I have created a cable size calculator for Android as it happens, does the calc in full and checks Zs and performs the adiabatic calc.
It's on the google play store here https://play.google.com/store/apps/details?id=com.electricalengineer.cablesizer&hl=en_GB
If you find it useful please leave a review, if not, please tell me why and I will look into making improvements in it.
Regards
Simon
Suggest you read the forum rules re-advertising.
Sorry Resu, it was an answer to a direct question about cable sizing apps on Android though. Didn't intend to break the rules.
You're alright mate just thought I'd warn you. Newly signed up members advertising within their first few posts is a little dodgy! But in this case it seems justified :)
Reply to Cable calculator for Android? in the UK Electrical Forum area at ElectriciansForums.net
Im currently in my apprenticeship and completing an assignment that involves cable calculations. Im currently stuck on how to find the design...
Hi. Im looking for some advice when calculating submain cables. Basically there is a new connection of 80Amps that is to be used for a dwelling...
Hi All, I'm new to Amtech/Trimble and I've been asked to review a model. I'm looking at circuits that are SWA cables using the armour and an...
Hi all, Hope you're keeping well I'm currently wiring a small commercial premises. 3 phas incoming supply, 16sq cables As it is in an urban...
Happy New Year all. Quick question regarding cable sizing. I have a 25m run from DB to car charging unit. The 25m run will mean approx 8m is run...
