robd
Afternoon all,
On an extension job, customer wants a cable run to a pond which is 70m from the house, for oxygenation and some lights.
There are quite a bit of groundworks going in including all the drains which will be running downhill to said pond and are being dug currently.
Builders want power to go down whilst all the digging is being done. Question is means of getting down there, usually I'd ask for standard 500mm trench but in this case it will probably go in to the side of drains well below surface. What I had thought is SWA inside Black electric cable polyduct as per link here:
Electric Cable Polyduct 32/37mm Black Smooth Single Wall - 100m | Drainage Superstore® - https://www.drainagesuperstore.co.uk/product/electric-cable-polyduct-3237mm-black-smooth-single-wall-100m.html?gclid=EAIaIQobChMIoKCC_KzC3QIVAvhRCh1uxweOEAkYAiABEgL79PD_BwE
Just wondered a. if anyone had a better idea and b. if you've used the duct before is there somewhere else it can be bought short of phoning round builders merchants.
Thanks in advance.
Afternoon all,
Thanks in advance.
Some Garden is that.
Why the expense of the duct? Buried direct is perfectly acceptable.
Living where we do the soil is clay, the house comes in the local authority Broads Authority so would expect the ground to be sodden at that depth in the winter, it's a pretty deep trench.
robd
East Anglia
Cable duct for under ground SWA
robd,
robd,
