Discuss Cable tray in the Commercial Electrical Advice area at ElectriciansForums.net
i don't think there;s a hard and fast rule. i reckon about 6-7-ft. ( thats around 2 french revolutionary made up metres)
Its actually a very simple question which has a very complex answer, too many variants here to give a rule of thumb even-
-Type of tray (light, medium or heavy duty)
-Load on tray (Plus possible future additions)
-The material your fixing to.
-Any changers to the tray run like bends, lifts and drops etc may need additional support.
-Method of support (using rods can be done in various ways like direct to tray or a trapeze set-up that the tray sits on and often the better option of these particular 2 methods)
....to name a few considerations
Manufacturers usually have a PDF for guidance so just find out who makes it and look it up online.
they should be outside the tray, supporting 8" pieces of unistrut. the strut then supports the tray. how else can you get rid of all those zebedees lying round in your kit?
http://www.schneider-electric.co.uk...ay_and_ladder_best_practice_guide_2012-11.pdf
Page 63 onwards. Basically you need to calculate the weight of the tray plus weight of the cables to be installed then use the manufacturers data of the supports to space them according to the weight of load. You also need to consider the location its to be installed and allow for any external influences likely to be incurred...Like wind etc if installed outside for example.
Yes Andy.
Gripple do a full range of hangers for basket, trunking and even ladder. Although with ladder it will still require some strut to tie it in if large fault currents are possible.
It's quicker (can be a lot quicker) but higher purchase costs.
All the cool kids are using it...you know, the sparks who wear camo snickers pants and sun glasses.
Yes Andy.
I tried to be cool like that in the summer and got arrested.
I actually am sporting crotchless work trousers right now. The missus will be stitching them this weekend though. The rip has been getting bigger and nearly had a few "incidents" in front of customers this week.
As for the gripple tray supports, I'll leave them to the cool kids. I like my tray non-swingy.
Used the gripple wire and assesories when working on a Hospital which was built on a seismic fault line. No stud allowed just double sided strut with fabricated plates used as Hangers. gripple wire for every other bracket. Expansion joints every 20 meters!! Nightmare
Reply to Cable tray in the Commercial Electrical Advice area at ElectriciansForums.net
This might come across as a really daft question to people who work with cable tray quite often but as part of my AM2, I am to clip FP200 to the...
There are electrical engineers who just mutter the slogan "Safety is the top priority," and simply convey old and inaccurate Cable Tray Weight...
I am trying to find how to price per meter for installation of cable tray 150mm x 150mm for a large commercial project.
I'm looking at fitting some cable trays in a domestic loft. I need them to sit 150mm above the current ceiling joists running across those...
Hi Guys Would I be correct in thinking an electric cable can be as close as 25mm to a gas meter ? (not that I'd ever be that close out of...
