Discuss Cables in cavity of walls in the UK Electrical Forum area at ElectriciansForums.net
Nowhere as far as can think without looking.
Just a requirement of the builders and the building inspector.
It's not a massive headache I've got no problem doing it.
Thanks, something I've often done too.
It was the "we are required" suggested it was a mandatory requirement......
I've also been required to place all cooker control switches to the right hand side of the cooker/ hob because apparently 95% of the population are right handed and wouldn't want the switch on the left hand side!
True story!
True story!
LOL. I'm right-handed but mine's on the left-hand side. That said, I didn't wire it.
But most of the ones I can think of are to the left of the cooker.
True story!
Blimey, if that got out, Jeremy Vine could devout a whole programme about that, not to mention not passing the 'Daily Mail test'. :)
True story!
My place has switch on LHS (not done by me) and guess what, its a perfect match for me. Must be destiny ...
Reply to Cables in cavity of walls in the UK Electrical Forum area at ElectriciansForums.net
I would like to hide the cable to an EV charger. The consumer unit, meter cabinet and charger would all be on the same wall. About 5 metres from...
Hello All. I'm quite new to this game and gaining experience, but going well in the main. My customer wants to feed a Hob ( on island in centre...
Hi, I have two questions about domestic wiring In Ireland 1. Should conduit be used when passing multiple T&E cables (2.5mm) through a garage...
Hello everyone, How do you think reference method and type of wiring for flat twin and earth in non-metallic conduit will be : just C and B...
I'm installing smart modules in my light switches which means I need to replace the existing 25mm back boxes with 47mm ones. Downstairs all walls...
