Discuss Cables in cavity of walls in the UK Electrical Forum area at ElectriciansForums.net
Hi all first post here but I don't think cables in cavities are permitted, directly through a wall is a necessity sometimes, (100mm cavity) but running 4 plus meters in a cavity, well what reference method is that.
It probably building regs that don't allow cables or pipes inside an external cavity wall.
I know plumbers ( gas n water) are supposed to sleeve a pipe that passes through an external cavity wall.
I guess it's good practice to do the same with cables.
Also, you have to seal the remainder of the hole to stop bugs crawling in and infesting your home.
Hi Nigel, welcome to the Forum !
I won't go through the negatives, but cables in vertical voids are described in the IET OSG Appendix D item (f) on page 133.
Reply to Cables in cavity of walls in the UK Electrical Forum area at ElectriciansForums.net
I would like to hide the cable to an EV charger. The consumer unit, meter cabinet and charger would all be on the same wall. About 5 metres from...
Hello All. I'm quite new to this game and gaining experience, but going well in the main. My customer wants to feed a Hob ( on island in centre...
Hi, I have two questions about domestic wiring In Ireland 1. Should conduit be used when passing multiple T&E cables (2.5mm) through a garage...
Hello everyone, How do you think reference method and type of wiring for flat twin and earth in non-metallic conduit will be : just C and B...
I'm installing smart modules in my light switches which means I need to replace the existing 25mm back boxes with 47mm ones. Downstairs all walls...
