Discuss Can an alternator be tested for output off a car? in the Auto Electrician Forum area at ElectriciansForums.net
Apart from feeding any writing you find on it into Google, then no.
Alternators only push out the power required from them, and I assume that the requirements for a kit car are low, so almost any rating will do, with the only penalty being weight and size.
Little Mitsubishi alternators used to be a favourite, but there may be another favourite by now.
Thanks Brian, but ignore the kit car par as it has no bearing... it's an alternator for a Porsche 911 cooling fan for a VW Type 1 engine. The one I have which came with the used cooling kit (no writing on it whatsoever) is fine for what I need, but I'm adding an electric heater so have been advised to up the alternator to 90amp. I just don't know what I have though.
An Alternator can be tested off of a car but you need a test rig and a motor to turn it. Might be worth while taking to a local auto electrician to check it out for you.
Test rig to see if it works is easy enough, but would this normally check its rating?
It occurs to me that I don't actually know what happens to an alternator at its maximum rated output. Does its output voltage start to drop off, limiting the current, or, do its output keep increasing until it self destructs?
A crude one will just burn out the windings - no different to an alternator in a generator. When it hits the limits of it's inductance it just gets hot and melts! The voltage will always drop as current increases in the normal way but unlike a generator that has an AVR to keep the rotor voltage even, a mechanically driven alternator has no means to do that as it can only turn at the fixed speed of whatever drive/belt etc is making it move. So eventually all that heat gets the better of it.
An alternator has a sense wire (sometimes an internal connection) that senses the voltage and turns the excitation on and off to control the output.
I agree with Brianmoooor that a simple test rig cannot check an alternators ratting.
Reply to Can an alternator be tested for output off a car? in the Auto Electrician Forum area at ElectriciansForums.net
Hello everybody from Germany! I'm feeling sick with this car, it won't start, just very rarely...please help me out. Car: Opel Corsa C 1.2 2003...
I used 12v dc from a 13 plate car battery to power a 12v dianamo dc motor and brought in an alternator to change the battery using the rotation of...
hi all, i have a problem of over charging on my 65 s type jag. i changed the voltage regulator for a new after market one same as what was on the...
I have a 1986 diesel van. I (foolishly i now believe) upgraded to a 150amp alternator. Recently, i was driving and when I turned the van of, it...
Hi guys, im currently trying to start my new big block chev in a chevelle but having issues.. im a full novice on electrics so be gentle ! The...
