Discuss Can I carry out EICR in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Can I carry out an EICR ?
Details are - I did serve my time as an electrician in the early 80's I have the SJIB part 1 and part 2 electrical installation certificates and a scotec ONC in electrical engineering,I worked full time in the electrical industry till 89 but continued to do ad hoc work as and when required when I changed career path.
I'm now semi retired working as a maintenance man for a company that rents out accomodation on a serviced apartment type basis thing.
Anyway they have approx 200 flats and will need EICR's at some point and I intimated to them that I could possibly carry them out with a bit of brushing up on the regs and testing sequence.I still have my old (very) test equipment but have said that I would require an all singing all dancing multi function instrument.
All the flats are the original wiring and no mods have been done to them.
In one location there are 49 flats all exactly the same I've had a walk round and at the most the only comments I could put down on an eicr would be bathroom fitting not IP rated,underfloor heating not RCD protected and plastic consumer unit (in cupboard,not under stairs) wiring to be teste is 1 circuit lights,2 circuits sockets and cooker circuit.
Back to original question can I carry out an EICR ?
simple answer is that if you are competent... yes. but also be an idea to get PI insurance.
Reply to Can I carry out EICR in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
I've recently has an EICR (report attached) carried out on my two bed flat because I need to rent it out for a year. The electrician has come back...
I'm practising EICRs on friendly locations as I'm still in training - technically done my 2391-52 but frankly need loads more practise. I've just...
Had an enquiry where the installation (commercial) is relatively new and client has requested a condition report. Probably 80-100 circuits plus...
Hello, I had an eicr done in 2021and it passed with four C3 items. They recommend next test date to be in 3 years instead of 5 on the certificate...
I trained as a electrician in the 70s but have long since retired. Just had an EICR test done on my property in advance of selling. I have a 60s...
