Hi there. I’m installing a secondary mini consumer box with a 40 amp RCBO.
The main tail that comes from the meter is 25mm2 and goes in to a Henley block and then another set of 25mm2 tails come out from this and go in to the main consumer unit of the house.
Mains service fuse is rated at 80amps.
my question is, can I connect a new set of 10mm2 tails from the Henry block that is going in to a new secondary new mini consumer box which only has one 40ampRCBO in it.
is this configuration ok?
please some one advice.
