Discuss CAN I CONNECT 10mm2 IN TO A 25mm2 Henley block? in the UK Electrical Forum area at ElectriciansForums.net
Status
Not open for further replies.
Vinny86
Hi there. I’m installing a secondary mini consumer box with a 40 amp RCBO.
The main tail that comes from the meter is 25mm2 and goes in to a Henley block and then another set of 25mm2 tails come out from this and go in to the main consumer unit of the house.
Mains service fuse is rated at 80amps.
my question is, can I connect a new set of 10mm2 tails from the Henry block that is going in to a new secondary new mini consumer box which only has one 40ampRCBO in it.
is this configuration ok?
please some one advice.
Can I assume you are not an electrician.
What range does it say on the henley block
It’s says 25mm2 to 35mm2 on the Henley block.
[automerge]1598210643[/automerge]
What is going on with that foam?....it’s not even pink!.....amateurs ? as above though what Henley is it?...and that’s really diy scope works mate...
I’ve removed the foam. It was to fill the gaps as a lot of insects were coming in
How will you be isolating the supply to carry out the connection?
What exactly are you doing and have you notified building control under Part P of the building regulations.
I’m going to add a proteus 100amp double pole isolator.
[automerge]1598210831[/automerge]
Yes Im
In the middle of filling the form out to inform DNO.
I’m installing a 32 amp 7kW car charger.
I’ll be honest and say you need to employ the services of an electrician. This isn’t a project to be undertaken by a casual DIYer.
These works are way beyond your capabilities and from what you are suggesting I recommend you seek the services of an electrician so the job can be certified in accordance to current requirements.
Thread closed.
Status
Reply to CAN I CONNECT 10mm2 IN TO A 25mm2 Henley block? in the UK Electrical Forum area at ElectriciansForums.net
Looks very strange to me. Obviously had a new fuse carrier fitted to it at one point but the two cables on the left go to the meter as normal...
Need help with a quote here. I’m wanting some sound advice. Was called out to the hot water not working so repaired the issue within the panel...
Hi, I have received conflicting advice about Main Isolator Switches and would appreciate forum member's help to plan a way ahead. Looking to the...
Deleted member 155212
I am replacing my under counter oven with a new 3kw one, oven is on its own circuit and isolation oven switch, the cable is either 4 or 6mm coming...
Ok. Can you cut a ring in half, add junction box, then run a spur off it? I thought it had to be from a socket? Mate of mine wanted me to see if...
