Discuss Can I replace these? in the UK Electrical Forum area at ElectriciansForums.net
DanUK
Hello! I am in the process of purchasing a new property which has a vaulted kitchen roof and beams. There are three uplighters on top of the kitchen units - 2 of which aren't working. They are sealed boxes so I need replacements.
Does anyone recognise what these actually are and have any suggestions of what I can buy to replace them? I would replace all three so they all match. They give off a warm white light.
Thanks for any help.
Picture attached.
I can't yet as I haven't moved in. No worries if there's no way of telling, it would've been nice to have the replacements ready as this lights up the roof and I think it'll be a bit dark initially otherwise.
As already said , it may be worth replacing them as a cheaper option in this case , s you've already said , something like a surface mount tilt fitting may do the job ...
Need X-Ray vision to see inside the box, I'm afraid. There are literally hundreds of possible lamps that might go in there and only one will be the correct one.
Perhaps you'll need to wait until you move in.
Reply to Can I replace these? in the UK Electrical Forum area at ElectriciansForums.net
I have three Aurora Fluorescent linkable (linked) under cabinet 'strip' lights (c.21cm each) under the kitchen cabinets and over the sink area...
I have a Firebird oil boiler that is controlled by a Honeywell timer (no thermostat) that has channels for hot water and central heating...
My kitchen has track lighting. It consists of three halogen light bulbs. I've had the fixture for more than 25 years with no issues. Last night...
I'm sorry if this isn't in the right place but this is my first time using this forum. I'm also sorry if i make some mistakes but I'm new to this...
I have a baffling problem with a newly-installed PIR floodlight and I'd like advice from the forum as to whether it's defective (and should be...
