Discuss Can LSF and grey household T&E be mixed together in a install in the UK Electrical Forum area at ElectriciansForums.net
As the question above states can I mix white LSF and standard grey domestic twin and earth together in a new installation.
The property is a domestic property being rewired so wouldn’t be any need for the lsf I just have a few drums of 1.5mm on the van and thought of using them instead of ordering more in.
Obviously the circuits wired in 2.5mm would all be in grey domestic rated cable as I have none and just the lighting circuits would be wired in the LSF I have. Obviously apart from the colour difference and difference in rated temperature is there any other obvious reasons why I shouldn’t use this.
Can’t find any reason to not use it and trying to save on buying the necessary 1.5mm just because of its colour.
Opinions on this please.
Thanks in advance.
Yes its fine just seems a bit of a waste of pricey LSF cable for a grubby domestic
That said if its old van stock then might as well use it up
Reply to Can LSF and grey household T&E be mixed together in a install in the UK Electrical Forum area at ElectriciansForums.net
Hello all, I wonder if I can get some opinion on my deliberations on an old TPN installation with numerous 1P sub-boards wired up with 16mm T&E...
Wouldn't normally note this as an observation on a report but feel I need to. The way the building has been wired is all circuits on L1 have been...
Evening Gents just after a bit of advice and what would you do differently. I have wired up 3 kw heaters in 4mm tuff cable (40 meter distance...
Hi, plumber here so please be gentle (or take the p-ss ;) ), I am supposed to be installing a UV water steriliser for a customer. I have some...
Getting desperate to clear my small garage, and I have a bit of old red/black T&E. I used a few bits to add a socket or two in my flat and a...
