Hi all, long time lurker first time poster.
I'm running a new supply to my garage, 6mm2 armoured over a 14m run. Most of this will be underground, and will be in 50mm ducting.
I can't find much information on how best to cap/terminate/seal the end of the ducting once it emerges above ground to prevent water and debris ingress.
At one end the cable will run up a wall approx 2m,at the other end it will run up the wall approx 6 inches then punch through horizontally to the interior.
Many thanks!
Many thanks!
