Discuss capping in the UK Electrical Forum area at ElectriciansForums.net
you are supposed to be doing the wiring under the supervision of the person who is going to sign it off as his own work. So he needs to supervise.
Hence my advice to ring the guy Ted. By rights he should be inspecting the cable runs as they pass through the under floor space and up or down the walls before they are covered over by plaster or floorboards, get on the phone. He's the one with his name on the cert, make him earn his money:)
Ted, this electrician of yours. Is he a Part P approved contractor?
The work you have described will need notifying to the Local Authority Building Control.
The work you are doing on his behalf needs to be inspected and tested in it's entirety by the person signing the work off so I would not fill chases or refit any boards that you have had to lift to run the cables.
If for any reason the spark you are using is not Part P registered then you may wish to contact the LABC to arrange them to inspect and test work before ANY work commences, during and on completion.
If this work does not get signed off appropriately using one of the two options available then you may find that you could end up 1) Not being able to sell your home in the future 2) Your home insurance policy may become null in void and 3) Not very likely but you and the electrician completing the work could be prosecuted and fined up to £5,000.
Oh there is always number 4) The risk of the house burning down or risk of serious injury or death if electrical work is not completed as per the very detailed schedule in design, installation and inspection and testing
Good luck:thumbsup
I agree with others, in that you really should contact your electrician direct as ultimately, he will be responsible for signing the installation certificate.
Good luck.
Reply to capping in the UK Electrical Forum area at ElectriciansForums.net
Hello, I bought a new build and noticed the upstairs MCB is controlling some sockets on the opposite floor, so if I flick the upstairs MCB it's...
This is a strange one, my neighbour is a bit mad, he had a largish extension built in about 2015, the builder attempted to do everything including...
Good day. First time poster. We recently had an electrician perform the EICR, as this is a newly purchased property I thought'd I would have the...
I moved into a house where the owner left an air compressor. He started wiring it before he left, said it works but needs wiring finished. It has...
Hi ive recently got myself a mig welder for my garage but each time i try to use it it trips out. Ive spoken to an electrician and he said its...
