Discuss Car garage ev charging in the UK Electrical Forum area at ElectriciansForums.net
Pricing up to install 2 22kw car chargers in a garage and possibly 2 more in the future for ev car rentals.
Must be lockable and record kw usage per car/RF card/pin and with an app for monitoring
Maximum demand of garage is between 10-20 amps per phase and have a 300amp tn-cs cut out but only a 100amp smart meter installed
The easee charger looks perfect but with a possibility of up to £2000 for extra o-pen detection .
Would prefer a zappie but would it have similar features
All circuits will be wired as a radial
Happy to be corrected, but if these charge points (and where the car is charged) is actually IN a garage, then surely TNC-S is acceptable without further measures.
There will soon (few months) be a zappi with rfid tags for commercial use but I would consider Sevadis as my first choice for this scenario.
Does all you need and more. the sevadis cloud back office software is one of the best out there.
Chargers will be on the external of building
Looking for chargers asap
UPDATE
Thanks for comments guys I have just done first fix and used easee chargers as were best for client control and monitoring
So I wired a sub main with new 8 way tp board and decided to TT board and got a ze of 6.19 ohm
Just to note
Reply to Car garage ev charging in the UK Electrical Forum area at ElectriciansForums.net
Hi. Not sure if it's the right place to ask, so won't be upset if it gets removed. Apologies if the terminology (PEN/PME/etc) is used...
7K
Hi all, I have my first EV charge point to install next week (not under OZEV grant), I was hoping to use a Zappi but looks like there is at least...
I have an install coming up where there is a 40 amp supply to a garage via 2 core 4mm swa buried. due to a rather expensive patio and other works...
I install a lot of EV Chargers from several different manufacturers. Got a problem that is baffling me though. Fitted a Rolec unit yesterday...
5K
Just a little thought here, With PME / TN-C-S supplies being most common, and the difficulty with EV charging from this earthing arrangement...
