Search the forum,
Discuss Car radio battery wire zero voltage ! but original car radio is working when connected. Why?! in the Auto Electrician Forum area at ElectriciansForums.net
thank you all so much! problem found! the black one is not ground, but the white/black is ! I have been following the wrong information from another webpage, saying that the black one is ground !
I just tested the blue/yellow (the battery wire) and the white/black, the reading is 12V ! while the original radio is disconnected.
Have chased many a Cr hifi loom and they can be murder ! probably even worse these days .My way years ago was to skip the stock cables for power and fit fused 12v cable and a better ground . Made huge difference .Also when adding relays for "120w " front bulbs !!! The stock loom cable would never work well.
Reply to Car radio battery wire zero voltage ! but original car radio is working when connected. Why?! in the Auto Electrician Forum area at ElectriciansForums.net
Hi Everyone, New to the forum but hoping I can find a little help with my restoration project... I am adding a secondary wiring "system" to my...
Hi auto-leckies, This is a DIY query. I have no electrician qualifications but I have electrical literacy, my original trades were heavy (HF)...
Hi everyone, When checking my consumer unit voltages with the full board off, I stumbled across something head scratching. Measuring the feed...
Once again I am using the Engineering chat as I think my question is more theoretical rather than 'diy advice'. If I am misusing the forum...
Hi, My camper has a new 12v battery and I have wired up a split charge relay with a 100 amp blade fuse near van battery and a 100 amp blade fuse...
