NICEIC Certification Scheme
After 40 years in the trade ,I will now have to come out of the NIC/EIC due to their requirement for level 3 inspecting and testing qualification. My father started the business in 1963,joining the NIC in 1965.After doing a full appenticeship in the 1980's I joined him in the business. I took over from him probably 10 years ago now and had to go on courses updating from my 15th edition to the 17th and then to the 18th. I got what the NIC called grandfather rights and have been inspected every year with the inspector commenting on how good a job I do.In December this year we will get a 60 years in the NIC certificate.
Now they want me to go on the level 3 course and i'm refusing to do it.It is going to cost me over £5000 in course fees,hotel fees and lost revenue and feel that I'm not going to recoupe this money back.At nearly 60 I've had enough and will probably downsize the scope of the business.Is anyone else in the same boat as me? I feel that from September of next year the NIC are going to loose hundreds of their customers due to this ruling.
It will hiss me off, who decides what you require regarding level 3 testing Nic, they are all run by insurance companys .
You should ask them you are running a company on behalf of them.
Does your local tech run it at nights? Should be a much cheaper way of doing it. I paid I think £30 for my 2391 course (granted not within the past few years!) which was 3 hours one night a week across 12 weeks.
Napit have not asked me for it yet.
I did the domestic installers course roughly 15 years ago. Each year I have a tingle of worry that they will question if my qualification is acceptable to continue to be able to notify my work. For this reason I try to keep up to date with the most recent editions of
"ELECTROTECHNICAL ASSESSMENT SPECIFICATION
FOR USE BY CERTIFICATION AND REGISTRATION BODIES"
I believe the current one is October 2024, but I haven't recently checked to see if there is a newer one.
If you look at P.25 it says..
"It is acceptable to permit new applications from an existing or previously recognised Qualified Supervisor, provided that they have been a Qualified Supervisor within two years of the application; and can provide a letter or similar evidence from the previous Scheme provider confirming their Qualified Supervisor status and the scope of Electrotechnical work previously assessed, which must be the same as the scope of work being applied for.
An applicant Qualified Supervisor will need to have at least 2 years’ evidence of responsibility for the technical standard of Electrotechnical work and evidence of ongoing Continuing Professional Development."
So from the above information, it looks like you could move over to Napit.
On page 27, Table A4.7 (dwellings only) and page 28 Table A4.8 (all electrotechnical work) it gives the 'Recognised qualifications OR equivalent' that are needed. Notice the OR EQUIVALENT.
Route 3 in both of these tables is 'Electrotechnical Experienced Worker Assessment (previously known as Mature Candidate Assessment)'.
I don't really know what this means, but it is clearly different from route 1 which is the Level 3 qualification.
Here are some links.. Experienced Worker Assessment | Electrotechnical Certification Scheme - https://www.ecscard.org.uk/content/how-to-apply-Experienced-Worker-Assessment
Good luck, and don't get disheartened. If you really find you cannot get registered then you can still continue to earn money by doing non notifiable work. I don't believe Tel had been registered for quite a number of years, yet he always sounded like he had work.
OP didn't mention the scheme they were in. ie Domestic Installer or Approved Contractor.
If you check the EAS compared to the scheme it comes down to tables 4E and 4F
4E is required for Domestic Installer
4E and 4F are required for Approved Contractor
Those above are basically the two parts of the full 2391
However if you did a recognised apprenticeship and or the AM2 which included Initial Verification then my understating is that for Domestic Installer you would NOT require a 2391 or equivalent qualification.
However for Approved Contractor you really would need the full 2391 which covers both Initial Verification and Periodic Inspection.
There is also the wording in the EAS that states the following
An ECS Registered Electrician Gold Card with the occupation of Installation Electrician, which will show the relevant edition of BS 7671, may be sufficient to demonstrate the qualification requirements in Tables A4.7 to A4.10. A grading of Approved Electrician may be sufficient to demonstrate compliance with the qualification requirements of Table A4.11. An ECS Card with the occupation of Maintenance Electrician may be suitable, only if the underpinning qualifications held align with the requirements of Tables A4.7 to A4.11.
In the above A4.10 is Initial Verification and A4.11 Is Periodic Inspection and Testing
Generally to get the Approved grade you would usually hold a 2391 or equivalent qualification.
Note above it says may be ...
I do not hold the 2391 or equivalent but did a full indentured JIB apprenticeship with the AM2 and it states on the AM2 results that I covered Initial Verification.
NICEIC said the above was not good enough to join their Domestic Installer scheme. this was a year or so ago. They insisted that the 2391 was required.
NAPIT said it was! and 2391 was NOT required.
I could easily get a gold card by sitting the H&S Exam if I needed to.
Thanks guys for the replies.I am an Approved Contractor.According to the NIC they are having to bring this in due to changes in the body (The EAS) that oversees ALL registration schemes.Napit will also have to abide by this so moving from one provider to another is pointless. I generally only do domestic work now but I do alot of testing for landlords so I don't think downgrading to domestic installer is suitable either.Obviously I don't have to be in a scheme to test and inspect and could issue a generic EICR certificate but most landlords want the NIC branding.
