R
Rusti
Hi
I'm a DIYer and I recently changed some light fittings and I have a niggling concern about how I've done it.
The old lights used ceiling roses, but the new ones are semi/flush and don't use a rose. I took 2 approaches:
For the first one I took off the cover of the rose to lower its profile, then put pieces of wood either side of the rose to create a platform to sit the new plate light on and ran a wire from the rose to the light.
For the rest I got rid of the roses and wired the circuits and some flex for the lights into a connector strip. Then I made the hole in the ceiling a bit bigger and pushed the connector in as far as I could before tightening the light fitting up to the ceiling. As it's a flat I can't go in from above to tidy the wiring in the ceiling.
All the lights work fine, and I'm comfortable that the wiring is correct and earthed, but I have a niggling doubt about how I've done it. For instance I was watching dragons den yesterday and the chocbox was on, and I read that old regs state that connector strips need covering with insulation tape, which I didn't do.
Could someone tell me if what I've done is ok, or whether there is a better way of doing this? I'm sure it's a job most electricians have done countless times.
Thanks in advance.
Thanks in advance.
