C
Contemptible
Hello! Complete novice here. I'm changing a plastic light switch to a metal one. There's a metal back box. I intend to run the earth cable from the wall into the back of the light switch faceplate. Then run another earth cable from the faceplate to the back box. Is it as simple as screwing in the 2 earth cables into the same terminal on the faceplate? Should they be screwed in on top of eachother or next to eachother? I don't want to kill my family, so thanks for your advice!
