Discuss Click flow connectors in the UK Electrical Forum area at ElectriciansForums.net
Think they are around 85 x 75 x 25 if it's the same ones I'm thinking about.
Just ask google ;)
For the right application a good way of connecting pre-flexed commercial LED downlights . We had some school changing rooms with plasterboard MF ceiling so no access for Klick LCM's wired LSF through joists and clipped. In the socket part you would struggle with anything more than 2 x 1.5mm 3 core & E LSF/PVC.
These are for some 50mm led's that are to be installed in recesses in a few bathrooms.
I would go for the CT101C 3 pole I think that they are 40mm. Out of interest what cable flex do you have at each hole ?.
  • Flow Connectors.pdf
Worrying if your actual boss thinks this is a good idea!
Then you know it's time to jack in. :eek:
I did say old, that's why I couldn't continue as Q.S any more when you are trying to maintain compliance with BS7671 and your M.D. is fighting against you anyway left over two years ago not looked back since much more relaxed no stress .
I'm not s Q.S but I know the feeling when you try to comply but your boss ultimately says"well I haven't priced for that"
One day I came back to the office and the locked filling cabinet where the NICEIC certificates were locked away was all ripped open with a hammer with a pile of certs on my desk with all made up information. Well you know the saying what comes around, had NICEIC visit '' can I see all the yellow copies of certs issued from pad xxxxxx well there they were marked void with made up results forged signatures.
Apologies Lee gone off topic a bit.
Reply to Click flow connectors in the UK Electrical Forum area at ElectriciansForums.net
This is confusing, I've ordered a few bits of this stuff, some switch modules and front plates and in the bumf on the website it says:- Click...
Electrical2Go - A Guide to Click Sockets: Which Is Right For You? Click Sockets Guide: Which is right for you? Click is a leading manufacturer...
Hi all, any advice would be greatly appreciated. Went to do some work at a factory unit on Monday ( changed 20 florries to LED battens and changed...
I'm obviously still new and learning about what I can and cannot do, but essentially I want to install an EVSE at my own house for an electric...
Hi, The shower pull chord switch has snapped at my mom’s home and having unscrewed the switch I discovered a horror show(see pic). So I’ve had...
