Discuss Cns anyone please help with this French Nano LED table lamp? in the DIY Electrical Advice area at ElectriciansForums.net
I would like to install a plug as the original one has been cut off. It has a black sleeved wire but also a non sleeved cable with no indication whether it is a live.
Can you please advise which type of plug I need for this?
Many thanks
Do you have the 24v power supply for it because it isn't mains voltage.
This is the other end of the cable with no plug.
No, I don't. I wasn't sure what to get. Are you able to post a link for the type of power supply I need?
Please see the photo attached. One end is connected to the switch but the other end, which supposedly had the power supply has been cut off.
Thank you
Do you not have the 24v power supply that part is probably a controller/dimmer.
Please see the attached photo, this has the +/- sign on it, I believe it to be the dimmer and the other end that's been cut off is the plug that goes into the socket.
You are missing the 24v power supply to which that cut off cable connected to. Fit a 13A plug direct to that it will all go up in smoke.
Yeah, it's a 500 euros lamp and I wouldn't mind having a go at fixing it even though I'd have to buy a power plug for a fraction of the price.
Details of the required power supply are on the manufacturers website that you posted.
I believe it's a 24 Volt 30 Watt supply, and you can probably buy the correct replacement from the original manufacturer, complete with interchangeable plug pins and the lead with a connector that plugs into the dimmer module you show.
If the correct replacement turns out to be over your budget, you could buy any 24V 30 W (otherwise quoted as 1.25A) power adapter, but you will have the job of splicing the low voltage cable out of the adapter to the lead you have, or alternatively fit a connector on your lead to match the output of the adapter you buy.
You will need to make sure that connection is the right way round for it to work!
Just an example:
Reactions: DPG
Just an example:
Hey Avo,
Thank you so much for such a helpful reply and the link as well, much much appreciated.
Best wishes
Reactions: DPG
Reply to Cns anyone please help with this French Nano LED table lamp? in the DIY Electrical Advice area at ElectriciansForums.net
Hi there, I'm hoping someone may be able to advise on whether my LED floor lamp can be repaired or not. The cable has split from the plug, as per...
Good morning guys, I bought this neon sign for my cinema room to put above my arcade machines. I have the cinema controlled by Google voice...
Hi, plumber here so please be gentle (or take the p-ss ;) ), I am supposed to be installing a UV water steriliser for a customer. I have some...
Hi All, Would be grateful for some advice. Would like to add an additional light (Undercabinet 8W LED Batten light) to a two-way light switch...
