I used to do maintenance for well known fried chicken places. Replacement of sockets was a regular job. When they are being used for loads near max and splashed with grease regularly it was inevitable and something they just put up with.
I found metal clad sockets lasted no better although obviously were better at taking knocks.
Sounds a bad and dangerous situation, all round. It does seem, however, that the damage 'around the pins' is occurring due to overloading. Exactly what items are fed from the d sockets?
I wouldn't recommend anything other than metalclad sockets and galv trunking anywhere near a cook line.
Agree mate but I didn’t mention any damage “ around the pins “ ! It’s not overload , just excessive heat , fat etc !
[automerge]1580059344[/automerge]
Thanks for your input Andy
Yes ! They are obviously
[automerge]1580059138[/automerge]
I agree mate , but as I’ve said I’m not the company going round charging a fortune to fit these kitchens and installing dado !!!!
Then they ought to employ someone that knows what they are about, rather than some Herbert that just does the cheapest install, with the easiest way without a clue as to the maintainability aspects.
[automerge]1580062988[/automerge]
I agree mate , but as I’ve said I’m not the company going round charging a fortune to fit these kithens and installing dado !!!!
Education, Education, Mate, time for a word with the management I think, if you have their ear.
Again Pete ! I agree
Sorry for misinterpreting....just with the scorching and cracking.....I presumed.
I try not to but it does happen.
Replace with commando sockets and plugs.
Could give a bit more wearability but again you're looking at environmental factors, rather than fittings.
Relocate sockets higher up the wall, if each socket is vertical drop then you're just shortening the cable/containment, then I'd replace appliance flex with a tougher rated cable; TRS or Artic, depending on which had the best properties for the job; this would improve the flex survivability potentially
