Discuss Communal Lights in the UK Electrical Forum area at ElectriciansForums.net
A
Abruno
Hey , just a quick one just doing some Communal lights been a while since ive done them, two options are needed. Some of the lights will be operated by there own pir and the other option will be if one pir is triggered all the lights will turn on simultaneously. All the lights being maiantained emergancy fittings. I have done some wiring diagrams so you can just double check it is correct lol
Cheers
Reply to Communal Lights in the UK Electrical Forum area at ElectriciansForums.net
What are peoples opinion's on this, pair of big old semi-detached houses (85 and 87) converted into apartments, dont think its a HMO although it...
Hi I'm in need of some advice. First of all i'm not an electrician but do have an understanding of electrics as i come from an electronics...
Hi guys, Been asked to fit 2 lights and a switch, which in reality turned out to be rewiring a multiple PIR setup to a single switch, adding...
Hi all, I'm looking for a couple of PIR floodlights to replace old halogen ones, probably around the 50W mark would provide sufficient lighting...
