Discuss Connecting a ceiling rose back together in the UK Electrical Forum area at ElectriciansForums.net
and please don't tellme you've squeezed 3 earth wires into 1 piece of sleeving. !!!!!, arrrrghhhh.
So what happens next you stick the rose up in the ceiling? Don't anyway. Are you putting up a replacement light fitting with a flex from that rose? Don't. Bit confused as to is that the new fitting or old one, the rose.
Are you posting all the lights one by one on the forum on how to wire it up? Anyway, answer to your question one brown in each of the terminals marked loop in the centre of the pendant.
In the centre 3 terminals, why is it hanging in space with the wiring coming in from the wrong side?
The OP shows no info on his profile, so I would guess he is a DIYer and knows no better. At least I hope he is a DIYer.
Reply to Connecting a ceiling rose back together in the UK Electrical Forum area at ElectriciansForums.net
Hi All. I need to extend the cables for a 3 plate ceiling rose/pendant on ground floor ceiling by 450mm. Can I fix the ceiling rose/pendant to...
Hi all was having a problem with lights work one min not next took ceiling rose cover off to find a stray black wire only terminal free is the...
Evening all, I had a quick Friday afternoon domestic job that has turned into a PITA and I'd appreciate your help. While adding some new lights...
Hi. Looking for some guidance please as I’m wanting to replace a ceiling rose fitting into a ceiling pendant. Done this many times but never come...
