Discuss Connecting nest thermostat to valiant eco tec pro 28 in the UK Electrical Forum area at ElectriciansForums.net
Afternoon all,
Just wanted some clarification about connecting nest to a valiant eco tec pro 28 boiler. They way I have read the installation manual is that you take a l/n 230v to l/n on heatlink . Then terminals 2 and 3 which are the common and call for heat are wired to the rt230v . The link on the rt24 v needs be removed . There is no additional stat on the system as the nest is being used for that.
If someone who has fitted one on this boiler before could let me know if I am heading the right direction it would be greatly appreciated.
Reply to Connecting nest thermostat to valiant eco tec pro 28 in the UK Electrical Forum area at ElectriciansForums.net
Hi folks, I'd like to get my Nest thermostat up and running with the gas combi boiler (Worcester Greenstar HIghflow 440 Standalone). FYI - I...
Good afternoon chaps, I have an Alpha E-Tec 33 combi boiler (with Google Nest 3rd Gen thermostat) that occasionally fails to put out hot water...
Dear community, as the Pro Nest are too fare away from my place in Italy, I am seeking here for advice. The actual work will be done then by my...
hi all , I’m after some help please , I’ve just had a glow worm boiler installed and wanted to add a wireless thermostat on , I just want to...
36K
Toneyz
T
K
ive fitted a nest thermostat to my CH system, which i believe to be a heat only system, but cannot get it to work off the wireless stat, it...
