R
revolt3k
Whats your thoughts when you see this behind fitting's guys
Looks llike the typical job by that well known partership Bodget & Scarper
Chris
not a problem infact they are supplied with conector and when done up the conectors are in an enclosure
A lot of jobs i have been to work on have a 4x4 junction box near the CU under the floor.Main feed in,feeds to each light and all switch lines back to junction box.There you go,one drop at each lightUnfortunately the companies that make these lights dont think of how they are installed, they assume that the flex can be taken above the ceiling, wired into a nice junction box and thats that, either that or they have some stupid tiny connector that only takes one cable rather than the normal 3. So how about some constructive suggestions.
What do you recon to the insulation tape tho. I guess its for a reason of some form?
So how is supposed to be done?
