Discuss Connectors behind lights & tape in the Australia area at ElectriciansForums.net
Like somone said, if its 1 T&E yes i would agree crimps would be good but how many lights do you see with just one cable?
If you use a joint box and make the hole bigger once you have made good the hole and painted it again how will access for inspection and test be possible as all connections need to be accesable for inspection once done.
I think we should design a new way for the makers of lights to do better connections behind lights. I want 60% of the profits tho :D
Reply to Connectors behind lights & tape in the Australia area at ElectriciansForums.net
Hi all, I am about to fit a light fitting and wanted some advice whether I should just connect the light cables into the correct terminal blocks...
Hi all, I was thinking to use heat shrink to strengthen usb cables where the cable enters the connector. I find the insulation starts to crack...
Hi all. I'm going to replace some sockets during a routine redecoration of our lounge including replacing some singles with doubles with USB...
Hi, my friend is having a floating shelf with a electric fire, and I’m between minds where to put the socket, I was gonna put the socket behind...
Hello, 1st time post from an amateur. I have some old Habitat decorative lights that are powered by a transformer. There seems to be a break in...
