Currently reading:
Consumer unit and RCD
Discuss Consumer unit and RCD in the UK Electrical Forum area at ElectriciansForums.net
Hi all, i have wylex CU protected with 2 80A 30mA DP RCD's i have had a new american style fridge freezer put in yesterday (dont think relevent). i have been in the cupboard and noticed that one RCD is up Red and the other is down Green, however everything is on. Any ideas at all before i call out a sparkie ?
Is everything working on the side of the CU covered by the "Green RCD" ? The Alarm, lights and the sockets. If the 3 circuits I mentioned are NOT working, then switch the 3 MCBs OFF reset the Green RCD and switch the 3 MCBs on 1 at a time which ever MCB trips the RCD then that is the problem circuit.
I've had this before, turned out all circuits were on first RCD, one busbar in CU instead of two, second RCD just sitting there doing nothing!
Do the three MCBs on the left turn off what they are labelled up as?
Everything thing turns on and off normally, just the rcd showing being off, everything thing is on, alarm, upstairs lights and sockets, which is confusing me, could it just be a dud rcd?
Have you tried resetting the RCD?, yes it could be just that a faulty unit.
Yes, they do. I tried turning the RCD on the left on and everything turned off. Possible overload?? Could something have moved and joined the two busbars together?
agree^^^^. if turning on the left hand RCD trips everything out, i'd suspect a wiring bodge up in the CU.
i have too come across similar, some cowboy had changed a consumer unit and did no pre testing. lots of interconnected circuits and additions over the years. when the new Cu was fitted it obviously tripped the rcds. so the guys response was put it all on one rcd... leaving the 2nd one in situ doing nothing. Turned out the cowboy was a kitchen fitter the husband found via friends at work.. who claimed to be fully qualified!
Reply to Consumer unit and RCD in the UK Electrical Forum area at ElectriciansForums.net
