G
Graham2
Hi guys, I'm not an electrician, I'm a kitchen fitter and shy away from any electrical work usually, allowing my mate who is a spark to do it.
I've built a workshop in my garden and plan to install several single phase woodworking machines. Consumption won't be massive as there will only be one used at once as well as fluorescent lighting as there are no windows.
1. What sort of supply should I run to the workshop? (Size of cable).
2. What sort of consumer unit should I fit? (We don't have an RCD board on the house)
I've looked at workshop/garage consumer units on Ebay. They all seem to have an RCD and 2 MCB's 6A and 16A. I am guessing the 6A is for the lighting and the 16A is for the sockets?
3. What is an MCB?
I know you're going to tell me to get someone qualified to do it and you're quite right. But this is on my own place and I intend to get my pal to look it over and connect to the main fuse board. He's very inconsiderately chosen this particular time to be in hospital, so as much as I want to ring and ask him what to do, my wife won't let me!
Your input would be most appreciated.:rockon:
Cheers guys. Graham.
An accurate answer cannot be given without knowing the ratings of the equipment you plan to use, the length of cable needed to get between c/u and garage amongst other things. Would really make sense to wait for your mate to be able to help you. In the mean time it would be useful for you to clear a path for the cable route, i.e. ducting under ground if the garge is away from the house
I can't believe you're considering doing the above, when you don't know what an MCB is. Stick to cutting wood pal.
I was going to post something on these lines but I keep getting accused of negative replies lol
- - - Updated - - -
- - - Updated - - -
must of hit enter twice lol
Find someone qualified in the north west with an excellent reputation to do the work.
Someone on this forum may be able to help find someone suitable for you.
A good electrician will help save you alot of time, effort and money.
The armoured cable you'll get installed may have to be buried to a certain depth on installation on the run from the consumer unit to your workshop.
Perhaps you could liase with the electrician to dig the trenches to his specifications for a long cable run and then let a good spark get on with the installation to meet your electrical requirements.
It would help the electrician to have more detailed information about the type of woodworking machines you intend to install - what their individual operational power consumption requirements are.
Led lighting may be a better for you than stark flourescent lighting.
Philips do excellent, reliable LED lights, that are very inexpensive to run, although not always to purchase.
Choose a warm white light 2700K (slight yellow hue) or 3000K (modern warm white light).
Flourescent lights are very bright at 4000K (cool white), a little austere for working long hours in a workshop.
Megaman do excellent 20W globe flourescent lights, which are equivalent to 90W lightbulbs with a light similar to a conventional light bulb, although this may not be suitable for a very large workshop, unless multiple lights are installed.
Graham, Find someone qualified on the Isle of Man with an excellent reputation to do the work. Electricians undergo extensive training for good reason.
Invest your time in finding someone suitably qualified, with an excellent reputation to do some of the work- they'll save you alot of time, effort and money.
Perhaps you could liase with the electrician to dig the trenches to his specifications for a long cable run and then let a good spark get on with the installation work to install the cable, to meet your electrical requirements.
Megaman do excellent 20W globe flourescent lights, which are equivalent to 90W lightbulbs with a light very close to a conventional light bulb, although this may not be suitable for a very large workshop, unless multiple lights are installed.
Hope this is of some help.
Thanks Vegelen. As I stated, I'm a novice and was asking for some guidance, hopefully in a civil manner, which you have given. I'll wait till my mates better and work under his instruction. Your advice on lighting is much appreciated. Thanks again.
It takes 4 years at collage and a G.B assessment for someone working in the industry 5days a week to be deemed competent to do a job like this!! I shouldn't even bother plugging in your computer to look on eBay again!! Wait for your mate to get out!! :)
College
Oops... Sorry! My screwdrivers never been 2 good at spelling!! As it happens though its quite handy when it come to wiring consumer units and sockets in workshops!! ;)
