L
LED Lighting
Hi all
Went to a bungalow today to install a bathroom light to find the CU had been installed in the corner of the attic.
The owner is a lady in her mid 50s. She has to claim into the loft (loft ladder) and across the attic to the corner (no boarded) to access the CU if it trips.
Would you class this as inaccessible or not?
CU install date Feb 2013!
Thoughts please
What's the cu location got to do with installing a bathroom light?
do the work and make a strong comment on the cert
Inaccessible? Yes
Relevant to fitting a light? Not unless it's inaccessible to you.
Was she there when it was installed if so why didn't she query it then
She left them be. She's nothe the kind of person to query it. She only mentioned it to me because my/her friend was there commenting on how bad of a location it is.
Where was the DB before it was replaced?
In the hallway. It was an old well Weylex cu.
From the sound of it she didn't like the size of it (16 module for 5 circuits) so he said he would put it up attic just inside the attic door
When she checked after she paid the final amount spark said it had to go in the corner because the cables where to short.
The property would have been suitable for a smaller currently or a recessed cu to meet the customers needs.
Hi all
Thoughts please
My thoughts
Business opportunity,
Quote to re-site it in a location of her choice.
The customer has proved it IS accessible, to all but wheelchair users.
However it's not ideal.
More importantly is why is it tripping regularly.
There many as inaccessible fitted at high level in attached garages with no adjoining door ,with floor to ceiling rubbish, coupled with a door that will not open without the secret twist code.
Ah, the old upside down lock, or latch that has to be turned 3/4 of the way otherwise it "goes over the top" and locks again
Or the brick against the bottom of the door and Code lock (1234 or 9999)
