H
High Tower
proteus boards can be mounted on pizza base then?
Or toast
if I remember correctly they came with a sheet of thin bakelite type material that fitted between the board and the mounting board,didn't happen that often though.And as for all the Wylex 3036 boards with open backs and that are made of wood?
It's too late to get the book out, but i'm sure that these roumors come fram way back when there were CU's out there, and still are, with open backed enclosures - wylex's etc, you still see loads of them.
Something about any switchgear likely to produce arcing etc.
Modern boards are not 'likely' to produce arcing unless under fault conditions.
As i say, too late to go digging so i'll leave my hat on.......
Its called Emmental !!!, or has the fancy cheeses not reached you guys in BLackpool yet?
