Discuss Consumer Units under stairs in the UK Electrical Forum area at ElectriciansForums.net
This perplexed me as I pondered why you ouldput a potential fire hazard under an escape route but then I thought surely that a) the enclosure should be able to self contain /smother a fire within it and b) even without the assumed protection of a), the stairs should be suitably fire rated as an escape route?
You may want to consider access though, the required height of installation is to enable disabled or otherwise infirm persons to be able to safely access. That object may be defeated if it's tucked away under the stairs.
And it also needs consideration/Hazard analysis/Risk assessment, that the inevitable junk that ends up under the stairs in a cupboard will inhibit access in the case of an emergency.
Simple
I'd have said yes given that the metal with appropriate fire barriers in place should contain and not aid the spread of fire.
However I personally wouldnt as from doing EICRs everyday I know it's a right pain because let's face it space is limited and normally that's where everyone stores their junk! And also it could depending on the house be difficult to meet part M of the building regs.
Reply to Consumer Units under stairs in the UK Electrical Forum area at ElectriciansForums.net
I wondered if it is OK to have 2 x Main Switches in the same consumer unit. One feeding the RCBOs in the House and one feeding the CU in a garage...
Hi. Can a horizontal 200A consumer unit be fitted vertically, or is there a vertical configuration? I have a 350mm wide space...thanks.
I have been asked to change cu from old fuse board which has 6 fuses. Only 4 fuses are used. The first fuse feeds cooker circuit. This is not used...
How should I wire a two way switch, so that I can switch it “on” at the bottom of stairs and “off” at the bottom of the stairs? It is currently...
hello all...whats the typical cost for a new consumer unit fitted and the old wired fuse box removed im in a semi detached house in...
