Light runs in green houses.
Having a control board with points for each light and then individually wiring every light back to the board 900ft away is not feasible would take MASSIVE amounts of cable, more feasible would be having a dtrbn Ring on LARGE CAPACITY contacts running the length of the light run from the control board. and controlling a few 100 lights per switch.
PS I dont think I said "ring mains" in any of my post, sorryy for the confusion.
That must be some crop! (hypothetically of coarse (sic.)).
As this is all hypothetical if its just the operational nature of the contactor then you have your answer, if this was a real set-up though at 900ft and 100 lights per run you have bigger problems with VD and dependent on the lamp type if they were in any way inductive at that amount your mcb would always trip on start and inrush would weld your contactor closed.. well just a few notes there to mull over regarding your set-up.
